Thinking about a drop?
Old Aug 18, 2007 | 08:58 AM
merc546's Avatar
merc546
Try
Mor-Drop Axles
600 29th Ave
Oakland, CA 94601
Phone: (510) 261-1888
Old Aug 18, 2007 | 09:35 AM
imlowr2's Avatar
imlowr2
Thanks Merc, you beat me to it. No website!
Mor-Drop
600 29th Ave., Dept. CT
Oakland, CA 94601
(510) 261-1888
Old Aug 18, 2007 | 09:54 AM
Randy Jack's Avatar
Randy Jack
The truck looks great, Ed!
Of course, I couldn't get it down my driveway.
Old Aug 18, 2007 | 10:47 AM
merc546's Avatar
merc546
Your welcome.
Your truck looks great. Need to know what you did to the rear. Sets perfect. It seems like your having as much fun with your steering as I am with my lighting quick brakes.
Chuck
Old Aug 18, 2007 | 11:54 AM
mamelukesword's Avatar
mamelukesword
Any Advantages?
Ed, Are there any Pro or cons to using a stretched stock axle or an aftermarket set up? What was the cost from Mor Dropp?
Old Aug 18, 2007 | 02:40 PM
mark914's Avatar
mark914
Looks much better!!!! who cares how it rides....it looks cool. lol
Mark
Old Aug 18, 2007 | 02:46 PM
novatattoo's Avatar
novatattoo
Looks even better now. Nothing like a great stance on an F100.
Later,Bill
Old Aug 18, 2007 | 06:25 PM
imlowr2's Avatar
imlowr2
I've never installed an aftermarket so I can't say. The stretched stock axle is pretty straight forward but there are issues which are a pain such as the draglink and alignment issues. I purchased the complete front end from a friend of mine for $300.00 complete with spindles, etc. By no means did it go in easy and was a piece a cake. More drop wants about $410 for the axle only. They have been around for quite a while.
Old Aug 18, 2007 | 06:30 PM
edsf100's Avatar
edsf100
Take those drive ways in-n-out on an angle. Looks GREAT! Welcome to the down under club.
Old Aug 18, 2007 | 06:36 PM
B/B ford's Avatar
B/B ford
Clean & Classy
How about some before and after measurements Ed? If you already gave them I,m sorry, I have forgotten.
Old Aug 19, 2007 | 12:03 AM
Kurt G.'s Avatar
Kurt G.
Ed, what did you do about tie-rod ends? I've read that you need to get dropped ends. Thanks Kurt G. Y-blocks rule.
Old Aug 19, 2007 | 12:40 AM
imlowr2's Avatar
imlowr2
BB Ford- I started with 8 3/4 inches with the stock axle. The drop axle took my front down to 6 1/4 inches high (ground to bumper) If you remember I had that small rubber band tires in the front. 215/45/17, which I've always hated. It just didn't look right and I still had a gap in the wheelwell, even after the drop. So I got a set of 225/50/17 which did the trick. I'm at 7 inches exactly now. I like it there. The front fender covers about half the tire now and looks much better.
Kurt - I'm going through hell right now with this subject. The guy who had my drop axle before, had the steering arms (part the tie rod connects to) bent down, so there was no need for the tie rod drop bracket like most guys are using. However when they bent the steering arm, it also raised the upper portion (ball end) which is now giving me the bump steer. I just need to somehow bend that upper arm down slightly and I'll be good to go. At this point, I'd recommend using the tie rod bracket. Much easier.
Old Aug 19, 2007 | 09:02 AM
  #28
mamelukesword
Question Tie Rod Ends
Don't they make extended length Tie Rod Ends so you don't have to use the Brackets. The Brackets are functional but they definately don't look good.
Old Aug 19, 2007 | 10:38 AM
  #29
imlowr2's Avatar
imlowr2
You are correct
Old Aug 19, 2007 | 03:22 PM
  #30
Kurt G.'s Avatar
Kurt G.
Thanks, I'm not a big fan of bending the connectors (or what ever you want to call them). Does the drop axle mess with the location the the steering box arm connects to? Will I need to bend that down? If so how? oxy/act torck for heat or what? Sorry about all the questions it's just I don't know and could use the advise. Thanks Kurt G. Y-blocks rule.
