ok have a 96 bronc with a 6 inch lift and 35 inch tires. At around 55mph it starts hopping, shaking really bad and the tires are chirping and stuff. Wheel locked up once on the freeway at 55. need help fast leaving for college later today
is this the rear end? front end? have you pulled the rear cover to inspect the spider gears. i also wouldnt drive it till you diag and fix the problem.
yeah come to find out it was the Inner/outer tire rods LEFT AND RIGHT. The ball joints, shocks. all messed up along with the tires. which were replaced today. It's gonna be about 2000 bucks to get back in motion.
