1978 - 1996 Big Bronco
Help Fast
Old Aug 17, 2007 | 02:39 PM
bobfromktown's Avatar
bobfromktown
Help Fast
ok have a 96 bronc with a 6 inch lift and 35 inch tires. At around 55mph it starts hopping, shaking really bad and the tires are chirping and stuff. Wheel locked up once on the freeway at 55. need help fast leaving for college later today
Old Aug 17, 2007 | 02:53 PM
Kemicalburns's Avatar
Kemicalburns
is this the rear end? front end? have you pulled the rear cover to inspect the spider gears. i also wouldnt drive it till you diag and fix the problem.
Old Aug 17, 2007 | 02:54 PM
nv_brewer's Avatar
nv_brewer
which wheel locked up front or back? if back, what's the engine doing, dies, bogs?
Old Aug 17, 2007 | 02:56 PM
bobfromktown
its all in the front
Old Aug 17, 2007 | 02:59 PM
nv_brewer's Avatar
nv_brewer
Is it both wheels? Do you have manual or auto hubs? How are your brakes? do they feel like they are dragging or pulling to one side?
Old Aug 17, 2007 | 03:02 PM
bobfromktown
manual lockers....breaks were just replaced everthing roters calipers pads etc
Old Aug 17, 2007 | 03:07 PM
nv_brewer's Avatar
nv_brewer
Could it be the axle nut is to tight causing the bearing to overheat and swell? Did you do the brakes or a shop?
Old Aug 17, 2007 | 03:14 PM
bobfromktown
Shop did the breaks.
Old Aug 17, 2007 | 03:23 PM
nv_brewer's Avatar
nv_brewer
Take it back. They may have over tighten the hubs. Good luck.
Old Aug 17, 2007 | 04:35 PM
Kemicalburns
i agree, take it back to the shop and have them reinspect.
Old Aug 18, 2007 | 08:43 PM
bobfromktown
yeah come to find out it was the Inner/outer tire rods LEFT AND RIGHT. The ball joints, shocks. all messed up along with the tires. which were replaced today. It's gonna be about 2000 bucks to get back in motion.
