Bed Capacity
Old Aug 16, 2007 | 10:06 PM
BuffmanLT1's Avatar
BuffmanLT1
Bed Capacity
I haven't thought about this, but figured after a search, I couldn't find what I was looking for so I better ask.
Truck in question, 91 Ranger, 2wd, 5spd, short box. I was wondering what the bed capacity is?? I've got an engine, engine stand, and some misc parts to pick up this weekend. Truck has fresh shocks in the rear and 1yr units up front.
Matt
Old Aug 16, 2007 | 10:51 PM
cddz's Avatar
cddz
I believe that the capacity of your rear end is 2550Lbs. You should have a 7.5 year end. find your axle code on the drivers side door. Far as wieght distribution usea sheet of plywood if you are concerned about putting holes in the bed.
Old Aug 16, 2007 | 11:14 PM
BuffmanLT1's Avatar
BuffmanLT1
correct 7.5" 10 bolt. Im not conerned about the bed really. actually pretty solid. This is my first truck so I wanted to make sure it was okay to haul that much in th bed
Old Aug 16, 2007 | 11:26 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Engine and a stand? And extra parts? Easy.
Old Aug 16, 2007 | 11:34 PM
khadma's Avatar
khadma
Carpenter Local 745
Your Ranger will do the job and beg for more!
Off subject warning!
Bigrigfixer- Did you write in to Dirty Jobs yet? They are still looking for topics or the plug will be pulled on the show!
Do it for FTE!
Old Aug 17, 2007 | 05:32 AM
BuffmanLT1's Avatar
BuffmanLT1
okay just wanted to make sure. I think fully dressed the engine is around 5xx lbs.. Thanks guys
Matt
Old Aug 17, 2007 | 07:22 AM
Rangerman Stan's Avatar
Rangerman Stan
Buffman, I've carried a complete Ford 400M V8 fully assembled with engine stand and some other odds & ends in my 91 Ranger supercab and had no problems any of the times I've done this. Your truck may squat a bit but it should handle it just fine. For better stability of the engine we had it laid down in the bed instead of keeping it on the engine stand. We laid it over on a couple of older tires. Have fun with your move.
Old Aug 17, 2007 | 09:36 PM
BuffmanLT1's Avatar
BuffmanLT1
yeah I got a tire to set it on so it's not top heavy. Going to get it next weekend since my friends trans finally died after 250k and the car was in front of the garage.
Old Aug 19, 2007 | 12:22 AM
bigrigfixer
The Pacifier
Yeah, I just wrote in.
Can you believe, as I was registering, someone took my screen name? So look for my post by bigrigfixer1.
