How much does a fully dressed 6.8 L V-10 weigh. Anyone have this data, I need to decide between an engine lift or a jib crane in the garage. Thanks in advance.
[updated:LAST EDITED ON 26-Sep-02 AT 10:03 AM (EST)](sorry monsta, just saw your post! so i guess it is safe to say
it'll come in between 450-800 pounds then)
I called my Ford service contact at a dealership and he
said a fully-dressed V10 would come in about 450-500 lb.
Thanks for the speedy reply guys, I think I'm going with a 1 ton roll around jib to be on the safe side, I will be able to use it for other projects I work on.
Gee, I read on a page that the 6.8 weighed less than the 5.0 HO... This guy mentioned it because he swapped a V10 into a V6 Mustang, and it came out lighter than it would have been with the V8.
That's pretty impressive, because the HO weighs 430lbs or so.
