1978 - 1996 Big Bronco
need help
Old Aug 16, 2007 | 05:35 PM
drunkdave's Avatar
drunkdave
need help
My buddy and I are working on a 89 bronco, 351W and a C-6. It surges at Idle, will stall when first strated, if cold. No vaccum leaks, new fuel pump, new idle air control valve. When put under a load, it will blow vaporized fuel from the ( I beleave it the crank case breather hose, the one goes from the air cleaner to the oil fill neck.) Could these to problems be connected? We have no Idea where else to look.
