rim again
Old Aug 16, 2007 | 03:24 PM
johnmvtv's Avatar
johnmvtv
Question rim again
ok,i posted something about a month ago about my cracked rim.DO NOT WELD CRACKED RIMS!It was a horror show leaked ,had it welded like,4 times and its not worth it.Now i have a question... I measured my rims and they measure 16.5 across and the tires are 35/12.5.Does anyone know where to get rims cheap?.I cant afford alot of money but i also can't swallow my pride and buy just one or two rims.Also which is better for a truck that 4 wheels all the time steel,or alum thanks
Old Aug 16, 2007 | 07:49 PM
BEWOLD's Avatar
BEWOLD
sure hope nobody told you to weld your rims! A 16.5? advise going away from 16.5 wheels, Im sure every one else will do the same. Although you'll need new tires. 16.5 rims can be just plain dangerous, the bead is not engineered like most other wheels and does not hold as well (cant be aired down either). Also the 16 and 16.5 outer flanges are very much the same size and a 16 tire can mistakenly be mounted on a 16.5 wheel causing the bead to fail and possibly rupture. Could be something else bad but these wheels are before my time and all i know is to stay away. (16.5s have been banned in europe a long time ago) steel wheels are probably best for the budget minded. simple white or black spokes are cheap and can even be plentiful in junkyards. If buying used steel or aluminum inspect them carefully.
Old Aug 17, 2007 | 05:00 PM
johnmvtv's Avatar
johnmvtv
ok,thats really stinks to hear that 16.5 rims are junk.My tires are about a year and a half old.I dont want to junk $900 worth of tire .I still need to know where is a good place to get rims online,like i said i just want rims nothing fancy.. its pretty much a work truck
Old Aug 17, 2007 | 06:53 PM
mhg's Avatar
mhg
to get 16.5" wheels you will most likley need
to go to ebay
I dont remember seeing any 16.5 wheels at any site
check your local junk yards or used wheel dealers
Old Aug 18, 2007 | 12:11 PM
BEWOLD's Avatar
BEWOLD
American racing might still have them, check out the web site.
Old Aug 18, 2007 | 04:14 PM
mustanginca's Avatar
mustanginca
I would just get a set of black steels from summit.com or desertrat.com they should be about $60 bucks a piece or so. I think don't quote me but check it out.
cdherman
Feb 16, 2026 08:09 PM
Bobark
19
Feb 6, 2014 04:32 PM
dthompson
Jul 8, 2006 10:05 AM
rallyman
Mar 16, 2005 03:19 PM
rallyman
Mar 16, 2005 05:09 AM
