Budget Suspension?
Old Aug 17, 2007 | 09:05 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I can't imagine how rebuilding a stock front end would cost more than $250 - 300 including all the steering wear parts and brakes, unless you have to buy new backing plates and drums. Doesn't include the steering box either. When you're discussing any IFS, you need to remember that the steering box and likely also the column need a fair amount of fabrication, you are getting disc brakes and need to re-plumb that, add various valves and hoses, etc. not to mention a new M/C.
The comment about Ford vs Chevy is right on; Ford used some form of beam axles (incl. the twin I-beams) thru the 70's, while Chev went with A-arms in the '50's. Beam axles aren't as smooth or plush, but they are more appropriate to actual use as a truck....
Old Aug 17, 2007 | 10:56 AM
AXracer's Avatar
AXracer
The advantage to using the original FS is that no significant fabbing is required, you can upgrade it a part at a time, so it will get you on the road the quickest. If I was choosing a salvage IFS IMHO the Jag is far superior to the Volare especially if you can find an entire donor car and use the IRS as well. I'd much rather use something designed for a sports touring sedan of a similar weight than one designed for a low end econobox (in the lowest period of Chrysler's history) weighing 1K# less, but then I'm all about handling. If choosing an aftermarket unit my choice would lean towards Heidt or Art Morrison for the same reason.
Old Aug 17, 2007 | 05:59 PM
lowtrkn2k's Avatar
lowtrkn2k
Originally Posted by mymerc
If you are decent at welding it is simple to fabricate with only a few minor pieces of mild steel to box in and make a bracket or two. Can be done with out cutting the frame at all for a 4 inch drop at least and with cutting you can take it lower. Mymerc
I would be interested in learning more about what it takes to get this under a truck. This could be another good option.
Ax, with the Jag there is no need to offset the engine and you get power r&p which to me seem's like a big plus. Are there any negative sides to the Jag IFS?
Old Aug 17, 2007 | 06:07 PM
AXracer's Avatar
AXracer
The only neg is finding a donor. The required years had bodies made of compressed rust and were primarily purchased by $$$ Old F**ts. They are scarce where the retirees tend to not gather. When you do find one they are cheap tho. They require very little metal work, nearly a bolt in.
here's some good info: (oops new link)
http://www.uk-hotrods.co.uk/v2/garag.../me/page_1.php
Old Aug 17, 2007 | 06:17 PM
lowtrkn2k's Avatar
lowtrkn2k
I'm leaning towards the Jag. I only wish I could get a whole car and strip what I need but I don't have anywhere to store it so I will end up having to go the junk yard route. It will cost a little more but that's the way I will have to go.
Old Aug 17, 2007 | 06:36 PM
AXracer's Avatar
AXracer
Be sure to get the funny offset U joint for the steering.
Old Aug 17, 2007 | 07:25 PM
49willard's Avatar
49willard
I went the Jag route with a 350/700R4. It is a bit tight fit for drivers side manifold or headers with the positioning of the pinion of the Jag R&P. If I was to do another truck I would offset the engine an inch toward the passenger side. I would have liked to run ss block huggers (low $ and nice from Summit). A one inch offset would have made the difference. I am using the curved rams horn. See my gallery for some pix.
Old Aug 17, 2007 | 07:59 PM
havi's Avatar
havi
I'll have the Roast Duck
https://www.ford-trucks.com/forums/2...light=aerostar
Scott Hurley has nice pics of the Aerostar install in his gallery.
Old Aug 17, 2007 | 08:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
While I don't disagree with you on the choice, Volares were not a low-end econobox; they were the same car as the Dodge Aspens that thousands of police departments used. They came with engines up to the 360 V8, disc brakes to 11", and weighed as much or more in the V8 versions as any Jag. Check this page; you'll see it is a reasonable donor, but of course I can be counted on the Right Sider (stocker) side of this board and would not do either...
http://www.allpar.com/model/aspen.html
Old Aug 18, 2007 | 07:05 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Ross, I agree. Many were used as taxi cabs too. Any vehicle which can stand up to the abuse handed out by police and taxi use must be pretty tough!
Old Aug 18, 2007 | 09:25 PM
AXracer's Avatar
AXracer
Designed for durability is not the same as designed for excellent handling. Sorry if I misstated my comparison. Again it depends on your needs and desires which is the better choice for you.
Old Aug 19, 2007 | 06:47 AM
GreatNorthWoods
Right on! For some like me, durability is the number one consideration and handling second. For others those considerations may be reversed. I admit the Volare suspension is a little mushy but I like mushy...
