Painting firewall
Old Aug 16, 2007 | 01:15 PM
daveengelson's Avatar
daveengelson
Painting firewall
Any suggestions on best combination of primer, and or paint to use for firewall. Book calls for 60 degree black. Believe I made mistake by using a 'rust converter' the 2 stage water based stuff that sprays on pink and eventually turns black. Purchased an epoxy primer and intended to follow up with some type of hardnose top coat, but called tech line yesterday of the fairly well known distributor, HOC, and found the product was discontinued because there was a problem with the batch. Anyhow, thought would check an see if any suggestions.
dave
