bed squeaking
Aug 16, 2007 | 07:30 AM
bed squeaking
I have a 2004 F150 and the bed seems to squeak like crazy while driving.
has anyone come up with ideas to resolve this..
also i have noticed that the 3rd brake light leaks sometimes when it rains?? any ideas on fixing this?
Aug 16, 2007 | 07:49 AM
lube the tailgate latches. a lot of people have that squeak including myself.
the brake light. i used 3m strip caulk and it worked well. i have also seen people use foam in place of the seal or some other kind of sealer.
Aug 16, 2007 | 08:05 AM
when you say lube you mean with like lithum grease or something like that.
as for the brake light i laid down a bead of silacone buti guess it was not thick enough.
Aug 16, 2007 | 08:21 AM
yes. i personally use white lithium grease in an aresol can. works well and lasts a while.
yep i got that..... i will give it a try..
thanks
Aug 16, 2007 | 08:26 AM
sure thing. its annoying till you fix it thats for sure.
04 ,
2001 ,
2003 ,
2008 ,
bed ,
chassy ,
driving ,
f150 ,
ford ,
lightning ,
sqeaking ,
squeak ,
squeaks ,
squeeking ,
squiks ,
truck
