Which would you do next ? The SCMT or the Banks Stinger ? It will actually be a CAT back system. I can get the Dynoflow muffler, 3.5 inch tail pipe, and 4 inch stainless steel tip without having to get the air intake system. I already have a cold air intake. I have a 2000 F-250 Ext. Cab SWB 4x4 V-10 I tow a 26 ft. Sunnybrook RV, OR a 20 ft equipment trailer loaded with a 5000 lb, tracror. I have 3.73 gears, conbined with BFG 285/75-16 tires. So that combination really kills my low end torque. I don't want to get into swapping gears. I just need more POWER :-) Long term plans are for either Borla or Banks headers. Almost forgot, I also have the sonnax valve, tricumulator springs, and TruSpeed converter, so shifting is not a big issue.
SCMT $330. Cat Back $412.00
[updated:LAST EDITED ON 25-Oct-02 AT 01:39 PM (EST)]Fuel Injection Services Inc. Allentown PA. 815-444-1763 or 1-800-445-1816 Ask for Theresa.
Banks is the only system I have found with a larger than stock tail pipe. (3 inches stock, 3.5 inches Banks) I can't see buying another brand name cat back system with the same size pipe as the stock one.
They will also sell just the headers ( torque tubes as Banks calls them). $890.00
New here...don't know how much info like this we are allowed to share. I have no vested interested in Fuel Injection Services. I'm just sharing info.
>to share.
Mark,
Welcome to the site!
The info you shared is fine and will probably help folks out! So, thank you.
The only thing the webmaster asks is that you do not promote or advertise vendors who compete directly with the online store or refer people off-site to items that are available here.
