460 valve size?
Old Aug 15, 2007 | 09:47 PM
BLKFE's Avatar
BLKFE
460 valve size?
I need to know the valve sizes on the 1990 EFI Head as well as the 1995 EFI head.
Thanks,
Brad
Old Nov 27, 2007 | 08:53 AM
Tdvjensen's Avatar
Tdvjensen
1990 head: 1.98 intake/1.65 exhaust
1995 head: 2.08 intake/1.65 exhaust
Old Nov 27, 2007 | 06:09 PM
monsterbaby's Avatar
monsterbaby
where in the world did you pull that 1.98" intake size out for 1990 heads? It's wrong all the standard passenger car/truck heads used 2.08" intakes. only ones not were the cj/scj stuff. Even the vaunted DOVE heads were 2.08"
Old Nov 27, 2007 | 06:16 PM
Tdvjensen's Avatar
Tdvjensen
I will give you two links and you can see for yourself.
1) http://www.eqcylinderheads.com/stockreplace.html
2) http://reincarnation-automotive.com/...s-1-index.html
Old Nov 27, 2007 | 06:36 PM
monsterbaby
the first one is wrong, and I don't see anywhere in Scotts site where he even lists the valve sizes for the E7TE and F3TE heads.
there might be some confusion coming from this due to the fact that the 460 head casting for the first gen fuelie heads was E7TE, and in 87 ford went to a E7TE casting number on the 351W heads which would in fact have a 1.98" valve size as I recall.
Old Nov 27, 2007 | 07:06 PM
Tdvjensen's Avatar
Tdvjensen
Then it is what it is.
Old Nov 29, 2007 | 05:00 PM
RRISDON's Avatar
RRISDON
I own a 1992 and as stated above the E7TE heads have 1.98 intake valves and the F3TE heads have 2.08 I have measured both. My E7TE heads now have 2.08 valves in them. I have a set of F3TE heads that will go on when I overhaul it.
85lebaront2
Mar 12, 2014 05:51 PM
x_man586
Aug 19, 2013 08:02 AM
dutchlincoln79
Jul 11, 2010 08:35 AM
F-250 restorer
16
May 10, 2010 09:15 PM
jaimalade
Jun 15, 2003 09:52 PM
