Modular V10 (6.8l)
Engine block heaters
Old Oct 11, 2002 | 09:50 AM
BOB_G's Avatar
BOB_G
Hello,
I'm new here so if this has been a previous subject don't chew me too hard.
I've got some worries about cold weather starts of my 99 F-350 V-10. It doesn't knock or rattle but I want to avoid the problem if I can.
I need some advice on block heaters. My truck came out of Fla. and of course doesn't have the factory unit installed.
A company called Wolverine has a external oil pan mounted one that looks interesting. Any thoughts?
Thanks
Bob
Old Oct 11, 2002 | 11:52 AM
nafzimo's Avatar
nafzimo
Does this one help? It is fairly recent.
https://www.ford-trucks.com/dcforum/DCForumID43/277.html
Matt
2002, F250 SD, SC, 8' Bed, V10, 3.73 LS, Arizona Beige, ICI Stainless Step Bars, Truxedo Tonneau, Prodigy Brake Control, Flowmaster 40
Old Oct 11, 2002 | 12:19 PM
Y2K350's Avatar
Y2K350
The external unit that is glued to the pan is ok but I wouldn't reccommend it. They tend to fall off and get pretty beat up by debris. I think a block heater would be the best way to go.
2000 F350SDXLT,SRW,RC,5spd man,V10, Front Leveling Kit,4.30 gears, 285/75/16 Wild Country
Old Oct 11, 2002 | 12:54 PM
Monsta's Avatar
Monsta
Sit. Stay.
> Hello,
Bob, no one here would "chew" you! We're all glad that you stopped by. Hope you stay awhile!
Does it really get cold enough in IN to justify a block heater?
Old Oct 11, 2002 | 04:05 PM
BOB_G's Avatar
BOB_G
Thanks for the thread and the info.
Monsta, I've always been "retentive" about cold start-ups. My Bronco and F-250 used to clatter and knock when it got down below 25 degrees, and this one's alot more expensive!
I've not been impressed with the in-line coolant or blanket heaters, the adhesive pan units looked a little better. The wife say's no to me curling up with a blanket out there to keep her(the truck) warm!
I'm just looking to THE EXPERTS to get the scoop!
Thanks
Bob
Old Oct 14, 2002 | 04:29 AM
Edmo's Avatar
Edmo
I ran my F-250 V-10 in Anchorage last winter and I would plug it in when the temps got below 25 degrees just because I could. It does help get the engine and fluids up to temp quicker... Best thing is the heater works much sooner!
Get the "Block" heater style... Some people in the really cold sections of Alaska use the block heater, the glue on oil pan heater, and the under-the-battery heater. I don't think you will need that in Indiana.
Edmo
Old Oct 19, 2002 | 10:53 AM
V10KLZZ71S's Avatar
V10KLZZ71S
Old Oct 27, 2002 | 08:18 PM
superdutyspv's Avatar
superdutyspv
I lived in South Dakota, and never needed my engine block heater, ever. And it gets pretty darn cold up there. I now live in Massachusetts- Cape Cod. I wouldn't worry about your truck in winter.
90pioneer
Apr 29, 2013 09:15 AM
spikedog
May 18, 2009 05:17 PM
Wolverine69
Nov 9, 2006 03:41 PM
Robert6401
46
Jan 2, 2006 01:18 PM
Thornido
New Member Introductions
Dec 6, 2003 12:32 AM
