Sponsored by: Kumho
I-beam pivot bushing installation?
Old Aug 15, 2007 | 07:11 PM
gscottc's Avatar
gscottc
Question I-beam pivot bushing installation?
'75 F-250 2wd 390 4bbl c6. Any tips on putting the new I-beam pivot bushings in? I had to pound on the casings very aggressively to get the old ones out. If I cool them in ice water and carefully, sparingly lube the casing will I likely be able to drive the new ones back in with a hammer or should I take it to a machine shop and have them pressed in? Suggestions please.
Old Aug 16, 2007 | 09:54 PM
scrapyardking's Avatar
scrapyardking
I allways just smack them in with a hammer, or you could try using a c-clamp
Old Aug 17, 2007 | 06:45 AM
cujo8's Avatar
cujo8
I stuck mine in the freezer the day before I was going to work on the suspension and I also warmed the I-Beam hole with a heat gun a little. Then I took the frozen bushing applied a light coat of grease to the outside of the bushing and then I aligned the bushing to the I-Beam hole and used a piece of wood to protect the bushing and drove the bushing home with a BFH. Went very nicely. When you install the I-Beams back on the truck lube the bushing on both sides before reinstalling them and don't fully tighten the nut/bolts until the weight of the truck is back on the ground.
Old Aug 17, 2007 | 12:00 PM
gscottc's Avatar
gscottc
They're in! Froze & lightly greased them. Getting them started was similar to starting a soft plug - once I got it straight it was O.K. I started driving the first one home with a piece of red oak and a LFH but the oak destructed and I did it mostly by beating on it really __ hard with the LFH. Waiting to torque the pivot bolt until it's in normal resting position seems important because when tightened to the 120-150 ft-lbs spec'd the internal sleeve probably won't move and it seems like any axle pivoting will be allowed solely by the flexing of the rubber. Good tip, THANKS!
andyz77vette
Jul 2, 2011 10:54 AM
WHITE F150 ROB
Mar 9, 2011 09:55 PM
smashclash
Nov 28, 2010 12:37 PM
66f-100
Apr 14, 2010 05:58 PM
Dave Barbieri
Jul 13, 2005 05:58 AM
