stock roller cam engine
Old Aug 15, 2007 | 11:58 AM
airharley's Avatar
airharley
Did Ford make a stock roller cam engine for the 460? I haven't been able to find anything other then retrofit or conversion kits. The reason I am bringing it up is the lasted issue of Carcraft mentions pulling the roller lifters and retainers from the junkyard engines to cut down on costs since they really go bad.
Old Aug 15, 2007 | 12:19 PM
leadmic's Avatar
leadmic
No, not from the factory.
Leadmic
Old Aug 15, 2007 | 12:34 PM
monsterbaby's Avatar
monsterbaby
only the 5.0 and 5.8 as far as Iknow, and yes some guys do exactly that. you can even retrofit the earlier blocks most times for the roller lifters by drilling and tapping a couple places in the lifter gallery to screw the "spider" to
