hey what are you guys doing about replacement windows for your trucks? i need a drivers and passanger side window.. maybe a windshield somtime too.. is anyone making them still.. mine is a f250 1965 4x4
Ray
Any glass shop can cut new side windows (clear or tinted-right/left is the same) from glass stock. Since the side glass is flat, it's a piece of cake. When you replace the side door glass, now is the time to replace the weatherstrips. Glass shops sell new cat whiskers (inner/outer door glass weatherstrips), division bar w/strips, and inside door window channels. They can install them, too. The vent window rubber weatherstrips are available from FTE sponsors.
The F100/350 windshields are the same from 1961 thru 1966.
The THREE windshields are still available from glass shops.
Originally there were two. One tinted, one clear.
The third windshield is tinted with a sun band across the top.
C6TZ-8103100-C = Clear - NAGS # W602-clear
C6TZ-8103100-D = Tinted -NAGS # W602-tinted
Tinted with Sun Band NAGS # W602-sunband
The NAGS numbers are part numbers used by glass shops.
