head gasket leak.
well i just replace both of the frist of july and now drive side is leaking coolant.. just a lilte bit went cold go's away when hot .. i had the heads sent out to head shop and cleaned upand injector cups replace..
one of the guys at work thinks i should try retorgue the head bolts ???
or go back in replace the gasket and see what went wrong ??
99 f250 4x4 no mods yet...
I don't want to pee in your corn flakes, just wanted to advise you of that. I am not sure what milling the heads will do to the engine but apparantly it is not recommended. Between compression ratio changes and valve to piston clearance, I have no idea. Could this contribute to your leaking head gasket, who knows? Hopefully someone smarter will come along and explain this.
