Sponsored by: Auxito
Need help with blower speeds
Old Aug 14, 2007 | 09:49 PM
fatforty's Avatar
fatforty
I was driving down the street the other day with the blower speed in the medium range and the blower just quit. I have high speed but that is it, I really need the lower speeds so the inside of the truck is quieter. Where and how do I check this and find the problem? think it could be as easy as a switch? Thanks, John
Old Aug 15, 2007 | 10:25 AM
KingRanchMan02's Avatar
KingRanchMan02
Most likely a burned out blower motor resistor pack. It is located high up under the dash in the passenger footwell. Use an inspection mirror to spot it. Good luck!
Old Aug 16, 2007 | 07:08 AM
88Vmax's Avatar
88Vmax
I agree with KingRanch. I just finished fixing mine with the same problem, only had high speed for fan. My resistor pack was rusted out and the plug into was partially melted! It is not a hard job to do (less than an hour) and a mirror and a light does help. Look under the passenger side dash in the air vent, you will see a plug with 4 or 5 wires going into it. Remove the plug and I think the resistor pack was held in with 2 screws.
