egr disable?
Old Sep 10, 2007 | 07:03 PM
Fishin76's Avatar
Fishin76
The reason EGR does not work at WOT is that there is not enough vacuum to suck it in to the intake manifold. Vacuum is at it highest at idle.
Old Sep 10, 2007 | 07:15 PM
beer boy's Avatar
beer boy
maybe, but intake vacum is maintained at (efi) wot and the egr works on this vacum the exhaust gas is also forced into the intake from the exhaust gas pressure. i know that some will want to argue that but if they pull an egr tube off and run the engine they will have little to argue with. try it.
egr is disabled at wot to allow the engine to build designed power. its like when your ac system shuts off at wot or 100 calc load. it lets the engine use all avaible for hp and torque.
i have my egr system turned off, its only been one tank but there has been no difference yet in fuel mileage and the highway performance seems better. but more tanks are needed before i decide what if any bennifits there may be. if it makes no difference then i will admit it.
Old Sep 10, 2007 | 08:38 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
One other thing to think about is that the EGR wouldn't add anything (or subtract from) emissions at wide-open-throttle.
At wide open throttle, backpressure is high so you have pressure at the EGR port, and the intake is sure sucking a lot of air so could easily take what the EGR puts out.
But there's no need, because at wide-open-throttle, combustion temps are lower - which is what the EGR is designed to do - lower combustion temps to lower NOx emissions.
So, there's no reason for it to be on at WOT.
Old Sep 11, 2007 | 04:23 PM
Fishin76's Avatar
Fishin76
Yes, backpressure is there, which can reduce volume of exhuast gasses, but even though the intake is sucking lots of air, its through the butterfly, not through the vacuum lines. Think path of least resistance.
Old Sep 11, 2007 | 04:39 PM
krewat's Avatar
krewat
The EGR is plumbed between the throttle body (after the butterfly) and the exhaust. If there is backpressure in the exhaust, and the EGR valve is open, exhaust gas WILL be ingested into the intake at WOT.
My point is that it doesn't matter, because the combustion temps are lower anyway because of the inrushing cool air. So the EGR is pointless at WOT.
Otherwise, the EPA would certainly have made it operate at WOT to reduce NOx. Doesn't matter about max power ...
Old Sep 11, 2007 | 06:11 PM
MisterCMK's Avatar
MisterCMK
O RLY?
Vacuum on a gasoline normally aspirated vehicle is 16-22 in hg. With the throttle wide open there is little to no vacuum in the intake.
Turning off your EGR isn't going to make much of a difference at all.
Old Sep 12, 2007 | 12:41 PM
Fishin76's Avatar
Fishin76
Lets end this, read the wikipedia article.
http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
Old Sep 12, 2007 | 12:47 PM
Fishin76's Avatar
Fishin76
Krewat was the first person with the right answers. I bow humbly in his presence.
Old Sep 26, 2007 | 11:42 PM
Dave Severson's Avatar
Dave Severson
Wondering if someone could tell me what guys are hoping to accomplish when they use the "restrictor" gasket, as in a smaller hole, for the EGR valve???? I've been seeing them advertised a few places....
Old Sep 27, 2007 | 11:11 AM
krewat's Avatar
krewat
My '96 t-bird had a stumble on very small throttle applications - using an Autotap, I was able to figure out the EGR was coming on during the stumble.
I put a restrictor in the vacuum line feeding the EGR to keep it from coming on too fast - the hole in the restrictor was probably .010" or so...
It killed the stumble. My '97 cougar 4.6L does the same thing - although much less noticable.
This might be the reason for the restrictor gaskets. Or not
Old Sep 27, 2007 | 07:29 PM
Dave Severson
Could be! I keep seeing them on some of the modular performance sites and was wondering... Starting to gather up parts for a 5.4 build and was wondering....
Old Sep 27, 2007 | 08:22 PM
krewat's Avatar
krewat
Oh, and that '96 t-bird 4.6L still passed NYS emissions test on the dyno - which definitely checks EGR operation.
There might be another reason for vehicles with no backpressure... or some other drivability thing with souped-up motors...
Old Oct 3, 2007 | 08:12 PM
  #28
montecarlo31's Avatar
montecarlo31
Just wanted to throw this out, why, if EGRs are so great why does GM design it's LSX blocks without them. 4.8, 5.3. 6.0 do not use them and make great hp and torque and get without a doubt better fuel economy then a 4.6, 5.4
Old Oct 3, 2007 | 10:09 PM
  #29
krewat's Avatar
krewat
Probably because they have so much back pressure, the exhaust gases wind up back in the combustion chamber anyway Just kidding...
But seriously folks...
My 2001 V10 doesn't have an EGR either - the '99's did.
The EGR system keeps the peak combustion temperatures lower to avoid creating Nitrogen Oxides. If a motor can be designed in a way to allow the peak combustion temperatures to stay lower without an EGR, there's no need for it.
Although, the EPA requires one on passenger cars - I'd love to see how they get around the EPA requirement...
Old Oct 14, 2007 | 06:11 AM
  #30
elmo8641's Avatar
elmo8641
the cylinder can hold x amount of air/fuel. with the egr that is reduced by replacing some of the air/fuel mixture with exhaust. if there is 30% exhuast in the cylinder then there is only 70% air/fuel mixture. if there is less air in the cylinder then there will be less gas. the reason it is shut off at wot is you can not make max power. as far as any gain there is none. you do not loose any performance, and you do gain a little gas mileage. and you stay legal.
