Possible Fuel Pressure issue
Old Aug 14, 2007 | 09:54 AM
thomadm's Avatar
thomadm
Hey all, Finally got around to checking the fuel prsssure. Got 40 PSI with key on, engine off test connector to ground. WIth it running it was exactly 30 PSI. Pulled vaccum line off the Fuel Pressure regulator and it went up close to 40 PSI. My question is that 30 PSI seems a little low to me. This think has a miss for about a year now, and now its starting to stall if you turn the wheel, put it in reverse etc. It is running rich, and no codes. I have repaced, cap, rotor, plugs, wires, injectors, FPR, coil and fixed several little vaccum leaks, mostly in the AC lines.
Would low Fuel pressure cause a miss though? Im not sure what to do next other than start replacing fuel pumps.
Old Aug 14, 2007 | 10:06 AM
quicklook2's Avatar
quicklook2
replaced air filter?
Old Aug 14, 2007 | 11:37 AM
thomadm's Avatar
thomadm
Yes, replaced air filter. Also forgot to mention i took the throttle body off and cleaned it, the IAC and tested and adjusted the TPS. No change.
Old Aug 14, 2007 | 01:33 PM
subford's Avatar
subford
Your fuel pressure seems to be about 2 or 3 PSI low on both ends, maybe the gauge is off by that amount.
While cleaning injectors I first start to see a miss when it drops to about 26-28 PSI. The engine will die at about 22-24 PSI. This is all for a 302 engine but I think the 351 would be the same.
Old Aug 14, 2007 | 02:29 PM
pfogle's Avatar
pfogle
I think I'd be inclined to either replace the injectors, or have them cleaned. It sounds like you may have one that's bleeding off a little under high pressure.
Old Aug 14, 2007 | 03:41 PM
thomadm's Avatar
thomadm
The injectors were replaced with accel injectors about 6 months ago from summit. The PSI readings i took were with a cold engine. It seems to get worse when it heats up so i will try reading it again after a test drive. It just seems low to me.
When I took the vacuum line off the FPR the exhaust smell was normal and seemed to run better. With it off it was 40 PSI. This thing is a 90 302, so I am hoping that I have an external High pressure pump maybe? Not sure what year they changed it. It sounds kind of sick.
Old Aug 14, 2007 | 06:38 PM
subford's Avatar
subford
In a 1990 F150 your fuel pumps are inside the tanks, no pump on the frame.
The tank pumps will put out from 95 to 100 PSI on a blocked head and your pressure is regulated down by the fuel pressure regulator. The fuel pressure regulator on the 302 normally with high vacuum at idle is around 32 to 33 PSI and at WOT 40 PSI. No Vacuum (hose off or not running with pin #6 of the VIP grounded) some regulators will go as high as 45 PSI.
As long as it goes to 40 PSI with the line off and the engine running I would think the pumps to be OK.
Either the fuel pressure regulator you put on has a weak spring or you gauge is reading low by 2 to 3 pounds.
If you get any more pressure than 45 PSI your O2 sensors will star giving error codes (too rich).
