Have you tried a set of plugs, wires, cap and rotor? I am kind of grasping at straws aswell but if these parts are not 110% then you will not have as clean of a burn. Hope this helps.
Are there any others that had problems with "left or Front bank running lean? That seemed to be the code most often thrown. Also I checked the plugs- all looked stellar except the number . It was greasy and gassy smelling?!?
