Modular V10 (6.8l)
SCMT Won't Work
Old Dec 3, 2002 | 07:28 PM
V10KLZZ71S's Avatar
V10KLZZ71S
SCMT Won't Work
Old Dec 7, 2002 | 01:48 PM
JakeB's Avatar
JakeB
SCMT Won't Work
Just purchased a SuperChip Micro Tuner part#1715 for my 2000F350 with a V10. When it tries to establish communications I get an error message that says to check connections. Both end are connected just fine but it will not establish communications. Any ideas what the problem might be? The wiring to the diagonostic port looks just fine. I purchased the unit directly from SuperChips as there is no dealer in my area, and of course no customer service on Saturday. Thanks in advance, Jake.:-(
Old Dec 8, 2002 | 11:28 AM
HiTech's Avatar
HiTech
SCMT Won't Work
Look to see if the connectors and pins are clean. Is everything plugged in tightly? Ask ofen in the chip discussion area.
-Jim
2001 E-450 V-10 Superduty
Old Dec 8, 2002 | 07:03 PM
FTE Ken's Avatar
FTE Ken
SCMT Won't Work
Direct? Ouch!! Full retail mail order is expensive. You could have gotten here for a lot less (and we check email and the boards on the weekends). The unit is bad. Return it for a refund or exchange.
Old Dec 8, 2002 | 07:28 PM
HiTech's Avatar
HiTech
SCMT Won't Work
If they will give you a refund, order one thru this web site and you will save some $$$.
-Jim
Old Dec 8, 2002 | 07:30 PM
4x4x4x4's Avatar
4x4x4x4
SCMT Won't Work
I that's the case he would be better off returning it to the manufacturer for a refund and then buy it here cheaper.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
