1978 - 1996 Big Bronco
Bronco Closed Crankcase System
Old Aug 13, 2007 | 06:54 PM
brian777's Avatar
brian777
Question Bronco Closed Crankcase System
I have a 1992 bronco with a 351 and I have not used it in a while, i'm trying to get it back together but it doesnt seem to run right. If I remember correctly while the truck was running if I removed the oil fill cap there was suction. If I remove it now there's nothing. The truck has a fluctuating idle and I was thinking this might be the problem. I would appreciate any info on this. Thank you.
Old Aug 13, 2007 | 07:11 PM
b4hntn's Avatar
b4hntn
PCV valve stuck?
Old Aug 13, 2007 | 08:14 PM
brian777's Avatar
brian777
The pcv valve works fine.
Old Aug 14, 2007 | 08:17 AM
Kemicalburns's Avatar
Kemicalburns
do all the basics if its just been sitting for awhile and that includes replacing the pcv. tune up, oil change and tranny service along with fuel filter change. you might even run some seafoam thru it
Old Aug 14, 2007 | 05:21 PM
brian777's Avatar
brian777
I did all the basics, it really seems like a vacuum problem to me. Should I have a vacuum suction through the oil fill because I don't. Thanks
352Ford
Nov 23, 2016 09:45 PM
Spktyr
Feb 22, 2016 07:39 AM
Beachboy
Bronco II
Jan 29, 2008 04:17 PM
davdogg39
Oct 1, 2005 03:17 PM
corbin3651
Apr 19, 2004 11:54 PM
