1978 - 1996 Big Bronco
Bronco starting problems 92 Bronco
Old Oct 1, 2005 | 08:11 AM
davdogg39's Avatar
davdogg39
hi people, i have a 92 Bronco V8 351 EFI. You know that sound the engine makes when you leave the engine running and you by accident turn the key to start it and the car and it makes that grinding noise? Well my Bronco does this sometimes when i start the truck. It happens from a cold or warm start. I was thinking that since my key slot is loose that my be part of the problem. Any ideas? Thanks
Old Oct 1, 2005 | 03:17 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The starter is trying to engage on it's own after the truck is running? Probably wouldn't hurt to pull the ignition switch and check the wiring in the column since you say the switch is already loose.
khadma
Jan 3, 2017 01:35 AM
75_92_95
Aug 19, 2016 10:18 PM
catzr440
May 16, 2015 09:39 PM
ZombieSlayer
17
Oct 9, 2014 07:29 PM
dustermaniac
Oct 2, 2005 05:57 PM
