75 VIN Number Location
Old Aug 13, 2007 | 06:45 PM
79 Pulling Ford's Avatar
79 Pulling Ford
I just purchesed a 75 highboy out of state and am trying to get it inspected so I can title the truck. A previous owner painted the truck and removed the vim tag from the door and the stecker from the cab. I am now trying to figure out on the frame where the vin numbers are stamped. Someone told me that I could find them on top of the frame unber the batterty. Ilooked and had no luck. Any help would be appriciated.
Thanks,
Doug
Old Aug 13, 2007 | 06:55 PM
Mil1ion's Avatar
Mil1ion
Close !
Top of passemger side frame rail between rad support and firewall
Old Aug 13, 2007 | 07:57 PM
79 Pulling Ford
Vin
Is there anywhere in the rear that the number might be. Also, did they stamp the number underneath the motor perch. We went from rad support to firewall and found nothing.
Thanks,
Doug
Old Aug 13, 2007 | 08:11 PM
petes79f150's Avatar
petes79f150
I've seen one that was just up under the cab where you couldn't see it.Never woulda known it was there if I wasn't pulling the cab off the frame.
Pete
Old Aug 14, 2007 | 01:43 AM
bucks77ford's Avatar
bucks77ford
The number is there between the firewall and support, just may have to REALLY look for it. I found mine after I sandblasted the frame, but most of it was too rusted off to make out. The other one is under the cab, where you can't see it.
