steering
Old Aug 12, 2007 | 09:41 PM
menzfamfour's Avatar
menzfamfour
steering
i have alot of play in the steering i adjusted the wheelbearings what should i do next any help
Old Aug 12, 2007 | 10:32 PM
Franklin2's Avatar
Franklin2
Get someone to lightly wiggle the steering wheel while you are under the truck looking for loose steering joints.
Old Aug 16, 2007 | 10:33 PM
clunker86's Avatar
clunker86
you can also loosen the bolt on top of your gear box and tighten down the screw as far as it will go and then back it off one full turn. then holding the screw with a scwer driver tighten the bolt back up. i done this with my 86 and it took a lot of play out of the streeing
Old Aug 17, 2007 | 02:22 PM
Piffery1's Avatar
Piffery1
Check the rubber/fabric coupling between the steering box and the column shaft. Tie rods, ball joints, pivot bushings and radius arm bushings can also be problems.
reed1951
Ford Truck Parts for Sale
May 23, 2015 04:34 PM
beckman
Apr 17, 2013 11:54 PM
monkey533
Sep 20, 2012 08:38 PM
gusso
26
Aug 20, 2007 06:57 AM
cburwell
Oct 23, 1999 03:46 PM
