1978 - 1996 Big Bronco
93 Big bronco Speedo
Old Aug 13, 2007 | 11:57 AM
zoomie's Avatar
zoomie
My son's 93 bronco, equiped with a 5l & auto trans has a speedometer problem. It dosen't work. I as asked him if it was acting up before it quit, he says no, it just stopped working all of a sudden. He wasn't off roading so I don't think the rear sensor is bad. Anyone have an idea what I should check?
Old Aug 13, 2007 | 03:02 PM
Kemicalburns's Avatar
Kemicalburns
check all the fuses, then look into replacing the rear sensor its cheap. if that doesnt work then pull the instrument cluster and test the psom. you may need a new psom or a used one from a wrecking yard. you might also open the rear diff and inspect the tone ring. if its bent or missing teeth this will cause some issues as well. is the abs light on??
