1978 - 1996 Big Bronco
Airbag Removal Question
Old Aug 12, 2007 | 12:49 PM
mikebabyak's Avatar
mikebabyak
I have to replace one of the cruise control switches on my '96 Bronco and have to remove the airbag to do it. Is there anything special to do other than disconnect the battery 10 minutes before I take of the airbag. Looks like the airbag is only held on by 4 nuts right behind the steering wheel. Thanks for the info.
Old Aug 12, 2007 | 05:23 PM
lostin90s's Avatar
lostin90s
No I took one out last month . I just shut unhooked battery . As long as no power will be fine.
Old Aug 12, 2007 | 07:16 PM
b4hntn's Avatar
b4hntn
I read there is a capacitor in the circuit to store the electricity. Just give it plenty of time to discharge after disconnecting the battery.
Old Aug 13, 2007 | 05:54 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Iv'e pulled them plenty of times and have never touched the battery.
Maybe just lucky.
Old Aug 13, 2007 | 07:07 PM
b4hntn's Avatar
b4hntn
You said you need to remove one of your cruise control switches but did not give much detail. Is the switch visiably bad? Could it be the clockspring? The air bag light flashed a 3-2 code for a few months then the cruide died and that went on a few more months then the horn quit. I needed the horn for inspection sticker and the clock spring fixed all three issues.
