Need help identifying Steering Column Wires
Old Aug 13, 2007 | 09:40 AM
medicpg's Avatar
medicpg
I am helping my friend Clean up the wires on his 1956 F100. Well we got a good amount done, but now the Brake Lites Dont Work. I tested the switch and that works, and based on the fact we just rewired it I am thinking I put something back together wrong.
He has an old Ford Steering column without any key on it. Can anyone help ID the wires coming from the Column?
Colors are:
Blue/Red
Blue/Yellow
Blue
Green
Green/White
Green/Orange
Orange
Orange/Blue
White/Blue (2 different wires)
Yellow
Also can anyone verify does the the Brake switch wire go back into the column?
Old Aug 13, 2007 | 10:24 AM
sparky's Avatar
sparky
Try this site it has some wiring diagrams, I picked one for a 76 Ford F100 should be the same wiring.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
on edit
If the hazard switch is on the column the brake light wire does go into the column to the turn signal switch, I can't remember if the trucks with the switch external to the column are wired the same.
Old Aug 13, 2007 | 10:58 AM
medicpg's Avatar
medicpg
Thanks Sparky....there are a few colors on this one that are not on mine.
