trailblazer do you actually have a chip or do you have a pcm that was flashed by Jody. Big difference, if you have a flashed PCM you can NOT pull it and send it in and still drive the truck. if you have a chip installed you can pull it and still drive in stock setting.
look under your dash next to the park brake and you will see the PCM look at the end pointing at you and see if you have anything sticking out or have a plastic cover over it.
1- I am assuming the tow weights listed exclude truck weight
2- if I'm correct I think I need 40 tow and 60 tow,is there enough difference to get both
for me living up here in the mountians 40 tow and 60 tow was needed..i can go from 60tow at high EGT's and push the button for 40tow and the EGT's lower with out letting up....and yes there is SOTP diff..
good eye..i didnt see his sig..thought he had the super chip at one point and wanted the dp for his new ride..
ok maybe got that figured out,thinking about 40 Tow think that will cover heaviest trailer and 80 econo for now then when I can get VB will only have to rebuy $90 in tunes and add th rest I may want
I took a look at my PCM and it has the plastic cover over it. So, I guess I have the flashed pcm. The previous owner now that I remember said the setting was permanent. So in order to get the 140 or any other tune, I have to get the plug in chip?
[QUOTE=Trailblazed]I took a look at my PCM and it has the plastic cover over it. So, I guess I have the flashed pcm. The previous owner now that I remember said the setting was permanent. So in order to get the 140 or any other tune, I have to get the plug in chip?[/QUOT}
if your PCM is already flashed you should send it back to jody to have it put back to stock or maybe trade PCM's with him... yes you will need the F5 chip to have more tunes and change tunes..call jody before you do any thing...maybe he can just add stock to your chip..what tune is flashed on it now???..do you know???
1 - The weights people are listing exclude the truck weight. BUT when I was talking to Diane they do all their figuring as GVW not just towed weight. She will go over it when you call.
Ron, the 80hp eco. is flashed on it now. Really, I dont need a ton of tunes,, I was just thinking the 80 and 140 (for fun every once in awhile). I very rarely tow anything past a 5x10 trailer so I dont need the tow tunes.
call jody tell him what you got..if you get the F5 chip stock is free..tell him PO's name and maybe he still has it on file and still make more tunes using your PCM set up the way it is now...let me know how you make out..i am curious my self...
i tow alot with a 90hp hypermax tune with no exhaust temp problems, if i switched to dp would i need anything less than an 80tow? b/c i was thinking of 80tow, 80 econo, 120, 140smoke and idle lope when i go to 120hp singles
