Sponsored by: Auxito
Tire size question
Old Jun 27, 2002 | 01:22 PM
broncman74's Avatar
broncman74
Tire size question
Hi I am new to this message board and am not sure if this has come up before but What size tires will fit on my 97 F150 4x4? It has the triton V8 and 5 speed. The stock tires look tiny and I want to go as big as posible with out rubbing or neeeding a lift. I will probably go with a semi aggressive tread Like BFG AT or something like that. Thanks,
T.J.
Old Jun 28, 2002 | 03:51 PM
slk's Avatar
slk
Tire size question
This subject has been the root of many discussions here. I've read that some folks claim they are running 305/75-16's without rubbing or lifts...others claim 285/75-16's are as big as you can safely go.
What I can tell you for sure is that I just put 265/75-16's on my 97 F-150 4x4. I went with Michelin LTX A/T's. They fill the wheel wells better than the puny stock tires, and they only reduce the gear ratio by about 5%, so the truck is still very driveable. If you go too big, you'll end up spending big $$ on taller gears to regain you acceleration.
Hope this helps.
Old Jul 2, 2002 | 08:37 AM
mtoombs's Avatar
mtoombs
Tire size question
Hi, I have a '97 F150 4X4 extended cab and my tires are 265x75R17 and I have no rub issues or problems other than the cost of the tires which is about $115 apiece at Sams Club.
Old Jul 5, 2002 | 12:43 PM
chadrock's Avatar
chadrock
Tire size question
Old Aug 2, 2002 | 09:43 PM
rkjerue's Avatar
rkjerue
Tire size question
I am guessing that you have the 16 inch wheels if you do there are a couple of options. They are 265/75-16 and (BFG AT just out) 275/75-16 would be that max. Now I know that you can probably squeeze 285/75-16 or maybe 305/70-16's but they will rub given that right conditions. I would also look at the spec's of the tires your a looking at just because the size is 265/75-16 does not necessary mean that Outside diameter and width is the same it varies from brand to brand as much as a few inches based on tread depth.
My favorites are:
(Cooper ST 265/65-16) http://www.coopertire.com (less expensive than BFG AT's)
(Parnelli Jones Dirt Grip 265/75-16) http://www.dirtgriptires.com (same price more aggressive than BFG AT's)
jc8825
May 15, 2011 11:02 PM
rufko72
2004 - 2008 F150
Nov 11, 2009 11:23 PM
4getfulbj
2004 - 2008 F150
Jan 12, 2009 09:47 PM
jdhudall
1997 - 2003 F150
Dec 2, 2007 07:35 PM
bcoates
2004 - 2008 F150
May 19, 2006 02:56 PM
