1966 - 1977 Early Broncos
Power Steering
Old Aug 12, 2007 | 10:17 PM
IM1096's Avatar
IM1096
Power Steering
Hello to all, I'm usually at the Powerstroke Forum, but I have a friend who is having a very hard time locating a power steering gear box for a '75 Bronco 4x4. Apparently this unit is becoming "not available" through the regular parts houses. As I know there is a wealth of experience and information here on FTE, I'm sure somebody here can point me in the right direction. Thanks in advance for any help.
Old Aug 12, 2007 | 10:44 PM
four4x4fords's Avatar
four4x4fords
He will probably need to contact a EB speciality shop like Tom's or Jeff's The boxes are getting quite rare and expensive. I split mine and ended up putting the F-150 box on it due to lower cost and stronger design.
Old Aug 12, 2007 | 11:23 PM
IM1096's Avatar
IM1096
Thanks four4x4fords, was the F-150 box an easy install or did it require a lot of modification? What year Bronco do you have and what year F-150 box did you use? There are boxes to had for a ridiculous price, but my friend is not in a position to spend $1000 for a kit from one of the specialty shops.
Old Aug 13, 2007 | 04:02 PM
four4x4fords
It was a fairly simple conversion my 68'. Someone installed a EB P/S box from a later model on my 68 before I owned it, but I don't think there would be any major difference between a 68 or a 75 installation.
I got the bracket from B.C. Broncos to install the box. I had to drill a couple of holes and do a bit of welding to install the bracket. The stock Pittman arm from the Bronco worked fine, but I had to do some work on the steering shaft that was hacked together by a previous "craftsman".
I don't think I had to anything to the hoses to make them fit.
http://bcbroncos.com/info.html
Scroll to bottom of page for steering box info
Bracket kit.
http://bcbroncos.com/store/product_i...roducts_id=331
Hope this helps.
Old Aug 13, 2007 | 09:55 PM
getpower's Avatar
getpower
Have him go to an autowrecker and pull one off of a 70's truck. Thats what we did for my 70 Bronco that didnt come with power steering. We got it out of an F350 with a 460 in it.
Edit: I take that back, we got a power steering pump for my Bronco. But still, check an auto wrecker or see if wild horses 4x4 has anything. I know that they have full power steering setups for EBs.
Hope that helps.
Old Aug 14, 2007 | 01:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Power Steering Gear Box.
1972 Bronco (after s/n P40,001); 1973/75 Bronco w/Saginaw P/S / Ford ID Number: SPA-Z / Ford Part Number: D3TZ-3504-A
1972/75 Bronco Power Steering Gear Box Seal Kit: C5AZ-3C538-D
Seal Kit also fits: 1965/69 LTD/Galaxie; 1971/73 Mustang/Cougar; 1975/78 E150/350; 1977/79 T-Bird/Cougar; 1973/79 Torino/LTD II.
Old Aug 14, 2007 | 11:54 PM
RCrawler's Avatar
RCrawler
If you choose to change to a F series box, go with the hybrid 2wd/ 4wd box. It is a much better setup than the 2wd box because of the shorter pitman shaft. It will give better steering geometry and won't put as much stress on the frame. Check out BC Broncos for more information.
Are you trying to convert to power steering or find a replacement for an existing power box? It may be cheaper to remove your box and have it sent off to be rebuilt if you can afford to have your Bronco down for a couple of weeks. If there are no damaged hard parts, it may only be $200- 300 to rebuild. If you are looking for a good used box, I would sell the one off of my Bronco. I am having a Saginaw box ported for a steering ram, so I have no need for the current one. PM me if you are interested.
Jason
cassell1
Feb 19, 2015 11:48 AM
The blue oval
Nov 6, 2013 12:55 PM
jerry73
Sep 10, 2013 03:36 AM
17witha664x4
Dec 16, 2011 01:42 PM
dhobdey1
Dec 9, 2009 09:29 AM
