95 explorer gas issues
Old Aug 12, 2007 | 09:09 PM
oojbearoo's Avatar
oojbearoo
Unhappy 95 explorer gas issues
so i got the 95 explorer v6 auto 4x4 as a project but there is somthing i just cant figure out the first time i took this truck to get gas in it the gas leaked out as it was close to being filled (couldnt see where it was leaking from) so i took the truck home check it out and i cant find nothing since then ive filled this truck up 25 times just to test it even if it only needed 2 bucks worth of gas and it hasnt leaked once ? but the truck has a gas odor when running and the gas milage is bad about 9mpg on avg ive changed the gas filter, air filter , tires are new and filled properly, and i used the gas system cleanout liquid and havnt seen it do much better any ideas if this is all connected ? thanks
Old Aug 15, 2007 | 01:18 PM
geeshik's Avatar
geeshik
i think that you might be having problems with your evaporative emissions side of things on your truck. i am not sure what the gas leaking out could have been, but i know that there is a vent on the top of the tank and it has a valve that opens with increased pressure. Maybe it is dirty and plugged.
The odor could be coming from a bad charcoal canister, which i believe is located above your spare tire underneath. It is mounted to a bracket and it is kinda hard to identify, but it is a big boxy rectangular piece of plastic with lines going to it. This also has a vent on it that might be plugged, or it could have a leaking o-ring on an evaporative emissions line. If you can get it apart and inspect it, you might find your problem. i always coat my o-rings with a light coat of lithium grease when i take apart a fuel line. (Emphasis on the light)
Also, in front of your vehicle, on the driver's side above your fender liner, is a canister purge valve that could be bad or the wires that control it could be corroded. This will cause a fuel vapor odor sometimes and will also cause poor fuel economy and erratic idle along with overpressurization of the fuel tank which can be noted by a buzzing sound coming out of your fuel cap. i could be wrong, but this is my experience so far. i hope it is helpful.
zapola6
Modular V10 (6.8l)
Oct 11, 2015 07:54 AM
mmortensen
1997 - 2003 F150
Feb 3, 2013 03:17 PM
Leichardti
22
Jan 9, 2012 03:27 AM
5Rangers
Jul 25, 2011 09:42 PM
RANGER589
18
Jun 3, 2011 10:03 AM
