Modular V10 (6.8l)
high capacity oil pan
Old Dec 6, 2002 | 11:21 AM
paulm's Avatar
paulm
Old Dec 11, 2002 | 03:14 PM
69_bronco's Avatar
69_bronco
Does anyone know where to find a higher capacity oil pan? I tow a lot and want a little more oil to help reduce the heat load on the engine. Before you ask, it doesn't run hot now, I'm looking for a way to keep it that way.
Old Dec 11, 2002 | 04:39 PM
GAV10's Avatar
GAV10
Aftermarket parts are hard to find for the V-10. You can pick up a Summit or Jegs catalog and find parts for 302's and 351's all day long. The old "demand" part of the "supply and demand theory." When you do find V-10 parts they normally Expensive $$$$ I called a performance chip manfactuer and asked why the chips were so expensive for the V-10 as compared to the 5.4. His reply was simply low demand, so the chip has to be more expensive to recover the R&D cost.
GAV10 ( Mark )
Old Dec 11, 2002 | 06:09 PM
Big Dually's Avatar
Big Dually
You can have one made at a race shop. They will remove your oil pan and weld a larger bottom portion to it with cooling fins if so desired. It would cost a couple hundred bucks, I have a freind that works in a custom race shop and they do this once in a while. I plan to do this after the holidays. You can also add two large capacity oil filters, this will screw onto the bottom of the motor and use two long steel braided hoses that will go up two the engine compartment. This will be easy for service, say by the power steering, batteries or something. The hoses with the dual filters will hold an additional three or four quarts of the Texas tea, for extra cooling and longer engine life, as the oil won't get so dirty.
Old Dec 11, 2002 | 06:57 PM
Fishin Technician's Avatar
Fishin Technician
are there any drawbacks to too much oil, like in too cool of a temp.??????????
Old Dec 11, 2002 | 09:56 PM
HarryO's Avatar
HarryO
>a temp.??????????
Short answer is yes, won't burn off water/condensation.
Longer answer: The oil needs to get to an operating temp. that will evaporate condensation (esp. in winter) and to achive rated flow.
One reason why short trips that do not let the engine warm up are soooo harmful.
Now with that said, keep in mind that if you are already getting the truck up to operating temp. (and not overheating), adding a couple of filters and/or an external oil filter will NOT prevent the oil from getting to operating temp., this will just do a better job of keeping the oil from burning.
HarryO
Old Dec 13, 2002 | 12:20 PM
fsnco1's Avatar
fsnco1
MAG-TECH makes oil and tranny pans. They are very expensive though. I doubt you will see improvements worth the $$$ you will dish out!
Old Dec 13, 2002 | 09:28 PM
V10man's Avatar
V10man
I'm sure the added oil will help protect the engine but I don't thinks it's worth the added costs. I'd spend that money on a Banks system.
Old Dec 13, 2002 | 10:59 PM
4x4x4x4's Avatar
4x4x4x4
[updated:LAST EDITED ON 14-Dec-02 AT 00:02 AM (EST)]I'd spend that
I believe they already did .
There's always the option of a Diablo chip .
Old Dec 18, 2002 | 03:23 AM
Gary E K's Avatar
Gary E K
I think I will just change my oil more often..:-)
Old Dec 27, 2002 | 07:14 PM
69_bronco's Avatar
69_bronco
Well, after checking around, I think I'll spend my money on sythetic oil, and keep changing it at 3k miles. Thanks to all who responded.
Old Dec 27, 2002 | 08:19 PM
Quikirk's Avatar
Quikirk
Good decision
Old Jan 9, 2003 | 11:00 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
>all who responded.
My '01 has an oil cooler. The two coolant hoses going to above the oil filter are the cooler. If you had a larger oil capacity, I wouldn't worry about the oil being too cold because that oil cooler works as both a cooler and a HEATER. If the coolant is at 185 degrees, the oil will be too because of the oil cooler. If the oil gets TOO hot it starts to shed heat into the coolant.
art k.
Old Jan 9, 2003 | 03:00 PM
johnsdiesel's Avatar
johnsdiesel
Why don't you put a larger oil filter or an oil bypass filter or both on the truck? It would add a certain amount of extra oil.
Old Jan 21, 2003 | 07:15 AM
Lighthouse's Avatar
Lighthouse
Does anybody know of a company making a larger capacity oil filter?? I have not been able to find anything bigger than the 1/2 qt. stock size.
