Plastic Button Fasteners
Old Aug 12, 2007 | 03:04 PM
dcara's Avatar
dcara
The one that hold on all the weather striping on the bottom of the doors, and the plastic covers over the coolers, etc.. First how do you take them off without destroying them? Second, where do you get replacements?
Old Aug 12, 2007 | 03:08 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Two flat head screw drivers on either side and pry up. Then I use an pair of long needle nose pliers to pop the out, Easy-does-it is the rule. I found replacements at Lowes in the fastener section if any break.
Old Aug 12, 2007 | 03:14 PM
JIM ROLAND's Avatar
JIM ROLAND
Most auto parts places have a section for the "help" brand of products. You might find them there. If not try your ford dealer. If you have the kind I am thinking about they are hard to not destroy. Try prying out on both sides of it at one time and rock it back and forth, (i.e.: 2 putty knives etc. I have been able to re-use some by doing it that way. Best of luck!
Old Aug 12, 2007 | 03:21 PM
Green_Dually's Avatar
Green_Dually
I have bought them from autozone or advanced before,im sure pepboys has them as well.Every time i pull them off,i end up popping the head off of them.
Old Aug 12, 2007 | 03:58 PM
stormyrider's Avatar
stormyrider
I bought mine at the local Auto Value auto parts store. You could also try your local body shop.
Old Aug 12, 2007 | 07:45 PM
Crash1040's Avatar
Crash1040
They make a tool to remove door panels, makes it real easy but I would still plan on having a few replacements just in case. I bought one for my wife's car when I replaced her door speakers. Just google "door panel removal tool" and you'll find one.
Old Aug 12, 2007 | 10:25 PM
IDPisan's Avatar
IDPisan
I got mine from the ford dealer, .15 a piece
Old Aug 12, 2007 | 11:18 PM
dnvoss's Avatar
dnvoss
the new ruber stripping with the fasteners in it is about $15 a piece from Ford
I just replaced them all a yr ago
