Broken part, what is it called?
Old Aug 12, 2007 | 02:55 PM
jono_s's Avatar
jono_s
Question Broken part, what is it called?
i have a '92 f150.
i just had a failure in the drivetrain, where the driveshaft connects to the rear differential.
there is a sort of bracket bolted to the rear diff, which is what the u-joint is connected to. one side of this bracket (which holds one of the ujoint cups) broke off, so i will need a replacement.
i have the driveshaft removed, and new ujoints.
my questions are:
1) what is this bracket called (the piece that's bolted onto the rear diff that connects to the driveshaft)?
2) any idea if this will be a hard part to find? (so i can start planning alternate transportation if thats the case)
3) how to i get that bracket thing off? it has a different bolt, with 12 points on the head. can i get a socket for this at a hardware store, or is it a speciality tool?
i have a photo, but doesn't look like i can attach images in the post.
Old Aug 12, 2007 | 03:25 PM
Tdvjensen's Avatar
Tdvjensen
The piece that is attached to the end of the driveshaft via the u-joint is called a drive flange. To remove the drive flange, you will need a 12 point socket, which can be found at most hardware stores and I believe its 12mm as well. I would go and talk to a wrecker for the part, since it is going to be your cheapest option, or a drivetrain shop. A typical auto parts store most likely wont have what you are looking for.
Old Aug 12, 2007 | 03:43 PM
jono_s's Avatar
jono_s
thanks Tdvjensen.
i see you're from edmonton. i'm up in fort mcmurray so my choices of autowreckers might be nil as far as i know. i'll likely have to get it shipped from edmonton. is there a wrecker down there you'd recommend?
Old Aug 12, 2007 | 03:57 PM
Tdvjensen's Avatar
Tdvjensen
Kendale Truck Parts, ph: 780-476-1066. There is also Ed's auto salvage out of westlock, but I dont have number for them off hand. If you are looking at new, try Pat's Driveline, ph: 780-453-5105, they might not be that much more and I am pretty sure they'd do shipping for ya.
Old Aug 12, 2007 | 05:00 PM
jono_s's Avatar
jono_s
thanks a lot, appreciate it, i'll make some calls.
Old Aug 12, 2007 | 08:14 PM
subford's Avatar
subford
The Ford name for the part is "Driveshaft Centering Socket Yoke", base part number is 4A378.
preppypyro
Dec 6, 2009 05:40 PM
SHOpar
Jun 21, 2009 10:32 AM
nhill2090
15
May 13, 2008 01:02 AM
Papadawg
Nov 13, 2007 08:50 AM
MikeGV
Sep 18, 2005 07:34 AM
