oil pan leak
Old Aug 12, 2007 | 12:49 PM
tgil's Avatar
tgil
oil pan leak
here is my problem, the oil pan on my f150 has a crack about 2in up from the plug, any way to repair other than removeing it?
Old Aug 12, 2007 | 12:53 PM
RexB's Avatar
RexB
Removing and brazing is the best idea -- some peeps have brazed an oil pan while still mounted (i confess to being young 'n dumb before), I wouldn't myself now. 5 quarts of oil is cheap compared to engine fires or explosions.
Old Aug 12, 2007 | 01:20 PM
tgil's Avatar
tgil
removeing the pan looks miserable,didnt know if possibly jb weld or something else might work? if i remove the pan i would just replace it
Old Aug 12, 2007 | 01:52 PM
RexB's Avatar
RexB
JB Weld or SealAll Gas & Oil by Eclectic might work -- they both worked for me on gas tanks after I drained the fuel.
Steelbrush the steel real well, it has to be scored and clean to hold well. Quote: "On leaking objects, tape over the sealant and additional coats may be applied over tape." I don't know what kind of tape, never did it that way.
Old Aug 12, 2007 | 01:55 PM
tgil's Avatar
tgil
what kind of tape are you talkin about? should i use a high temp rated material?
Old Aug 12, 2007 | 06:24 PM
lostin90s's Avatar
lostin90s
I have used die grinder to clean up pan and just used JB weld . Have had last over 8 years on my last engine . But it will start to leak else where so I just put a nice coat on every thing I can reach. good luck
Old Aug 12, 2007 | 10:15 PM
netscaner's Avatar
netscaner
If it's not rusted but just cracked, drill a small hole at end of each crack to stop the crack from traveling. Then clean it down to bright shinny metal. Then solder it using a big 120 watt or so soldering iron.
Brazing is best, but dangerous unless you pull it. Soldering is safe and can be done without removing it. You can also sweat a copper strip over the crack.
Of course drain the oil first.
