Questions about a 2001 B3000....
Old Aug 12, 2007 | 11:46 AM
02Taco's Avatar
02Taco
Hey Guys,
I have a few questions for you about the b3000 "dual sport".
What kind of shocks do they come with stock? Are they decent?
Do the 3.0 Dual Sport models come with a rear limited slip?
My plans for this truck would be to maybe just do a spacer lift to level it out and then do a limited slip rear (if it doesnt have one already).
appreciate the answers and advice!
Old Aug 12, 2007 | 08:16 PM
Rockledge's Avatar
Rockledge
I don't know what a dual sport model is, but I suspect the shocks on it are the same you'd find on any other similarly-equipped Ranger.
All Rangers can come with LS. You have to check the Axle Code set forth in the Vehicle Certiification Label (driver's door) to confirm which axle it has.
Old Aug 13, 2007 | 03:47 PM
wendell borror's Avatar
wendell borror
If you have to get a lsd, go with the detroit tru-trac, they use gears instead of clutches, require no modifires. The truc-trac grabs like a bear and has great highway manors.
Old Aug 13, 2007 | 04:21 PM
02Taco's Avatar
02Taco
What is the advantage of the detroit tru-track over a stock limited slip ranger diff? I am asking cause the tru-trac go for about 500 bucks, i am sure i can get a limited slip diff from a junk yard for cheaper and swap them out right? Is there a write up on that?
Thanks
Old Aug 13, 2007 | 04:36 PM
wendell borror
The factory lsd are junk, thier not much better than an open diff. They have clutches that wear out, so I would be leary about a boneyard lsd. A factory unit may work for your needs, however, I offroad alot and have found the factory lsd to be about useless as they have a weak preload and don't grab verywell. The trutrac is allmost as good as a full locker. The factory unit may be allright for street use, sure isn't impressive off-road.
Old Aug 13, 2007 | 04:42 PM
02Taco's Avatar
02Taco
Questions answered. Thanks for the advice. I guess i will send the extra cash on the trutrac, from what i have read it is used on a lot of trucks.
