390 head
Old Aug 12, 2007 | 11:19 AM
the_hetz's Avatar
the_hetz
390 head
1234567890
Old Aug 12, 2007 | 01:13 PM
Bear 45/70's Avatar
Bear 45/70
Need to now number between the center spark plugs.
Old Aug 12, 2007 | 03:28 PM
baddad457's Avatar
baddad457
If it has the original D2TE heads, the chamber volume is 68-72 ccs. These yeild about 10.5 to 1 with flat tops and 9.5 with dished 390 pistons.
Old Aug 13, 2007 | 07:58 PM
390cobrajet's Avatar
390cobrajet
did they have a different combustion chamber volume if they had the thermactor tubes? I was told that if it did that they would be 68cc and the rest without the tubes varied from 72-76cc. but someone else can probably tell you more about this that I can. just dont get 410 pistons, your compression will be down at 8:1 if your lucky to have it that high. I say that because aparently supply houses like to sell them to you instead of the 390 pistons, just a rumor I heard. look at the compression height specification closely 1.775 for 390 and 1.6 somethin for the 410.
Old Aug 14, 2007 | 04:59 AM
baddad457's Avatar
baddad457
If you want the high comp pistons for a 390, order them for a 66-70 390 = 4 bbl for a car.
DrFord
18
Aug 28, 2009 12:39 AM
LedheadELH
18
Sep 19, 2005 05:05 AM
biz4two
Aug 3, 2005 11:04 AM
71LTD390
Apr 17, 2004 10:33 AM
