Is it a good idea to stack these?
Old Aug 11, 2007 | 08:06 AM
f350rebel's Avatar
f350rebel
Question Is it a good idea to stack these?
I have a dp-tuner and this chip was already on the truck.......
18K+ Power Module with adjustable Dial
  • Adds up to 85HP-120ft lbs of torque! (Stock Truck-No Chip) <!--
  • Dyno Chart, Click Here -->
  • Gain as much as 5 mpg, THATS RIGHT!
  • Increases oil pressure to injectors.
  • Quick install! Now works with Cruise Control.
  • Fully stackable with other chips!
  • We HIGHLY reccomend the use of gauges with this modification as this can cause high EGT levels when turned up.
  • For all 7.3L Powerstrokes 94-03
  • Click here for Dyno Chart
  • Install Instructions- Most Trucks
  • FREE Shipping (Lower 48 states only)!
Is it ok to stack this with the dp or should i just leave it off... i did notice that my oil pressure did decrease a little when i removed it... and how does this type of chp work is it just advancing the timing?
Old Aug 11, 2007 | 08:08 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
No, do not stack them. The tuning takes the engine as far is you will safely want to go. One good chip is better than two decent ones.
Old Aug 11, 2007 | 08:13 AM
15 and 92 Dad's Avatar
15 and 92 Dad
Dont quote me, but I think what you have is simiular to the banks six gun which is what I have, It just turns up the fuel to the injectors, same as 18K mod. I also have the d.p tuner, I have found that if I turn up the banks while the D.P is on 80econo for example, It just gives it more fuel and does not run as well. The D.P is all you need, the only time I use to the banks is to add even MORE SMOKE, but it definatly does not run as good when I do that!!!! Leave yours set on stock or 1 and just juse the D.P!\
Im sure someone who knows more than me will help soon!
Rich
Old Aug 11, 2007 | 08:17 AM
f350rebel's Avatar
f350rebel
i took it off and i think i'm going to leave it off...... When it was on the truck i didnt even really know it was on there it didnt blow ANY smoke the only thing i notice since i took it off is that my oil pressure is a little lower....I know that the 80 econ runs ALOT better than that chip did and it was supposed to give me 85hp and 120 tq.... I know now that that was a lie
