Engine Modification Help!
Old Jul 16, 2001 | 10:40 PM
fordextreme's Avatar
fordextreme
Old Jul 18, 2001 | 07:25 PM
97expy5_4's Avatar
97expy5_4
I've got a Expy 5.4l with the tow package... I've installed a K&N air intake system... Now I'm working on a Throttle body riser.. With this in mind... What kind of performance improvements might I get from replacing hte stock fan with 2 electric units???? Would this take some strain off the engine??
If so enough to make it worth while..???
I'm still stuck on which exhaust system to settle on....
Thanks
Old Jul 22, 2001 | 10:03 PM
fordextreme
I myself have been reading up on chiping my truck and ive already purchased a Diablo sport chip. As for my personal opinion on exhaust, i just cut the muffler off after the cat and ran a single 3" out the passenger side. sounds great and relaeased all that extra back pressure that was just too restrcitive.
Sean
Old Jul 26, 2001 | 12:39 PM
97expy5_4's Avatar
97expy5_4
Great sounding like Flowmaster 50 series or great as in loud???
Did you replace the whole pipe from the muffler back? Or just patch in pipe where the muffler once was??????
I my shelf was thinking about drilling with a masonary bit thru the muffler lenght wise... then just reinstalling.... Thus providing more thru put with out a terribly loud muffler....
Let me know what ya think...
Later
Old Aug 24, 2001 | 07:40 AM
nothingbutford's Avatar
nothingbutford
On the exhaust system. If you want a freeflowing system without the noise you should get a Banks stinger system. It will also make it sound better.
Old Apr 23, 2006 | 10:00 PM
ethanol03's Avatar
ethanol03
Thumbs up Horsepower/longgevity Of The F-150
From A Person Who's Operated On My Own 2003 F-150 W/4.56 Ltr And Work On Them Everyday.factory Horsepower Is Not Bad.since,i've Owned Mine.i've Had 0 Breakdowns.i've Done Very Little In Modifications-higher Psi Flow Injectors,higher Rated Fuel Pump,went To 255 Front/rear Tires,soft Cover Tonneau Cover,and Replaced The Exhaust System W/flowmaster 50 Series Racing 3 Inch Dual Muffler Exhaust System.has Nice Growl With Much More Off Line Power.have Considered The K/n Fipk Kit However,for The Cost Of The Kit,you Really Don't Gaijn Enough Power Or Gas Mileage To Make It Worth It. Ford Motorcraft/motorsports Does Have Avaailable A Shift Improver Kit For A Reasonable Cost Where All You Have To Do Is Drop The Pan And Bolt In A Few Replacement Parts That Would Take Approx.15-20 Minutes. Any Q's Contact Me.
