rough idle
Old Apr 22, 2006 | 04:59 PM
acourt's Avatar
acourt
rough idle
hi,2001 f150 4.6 115000 miles with a rough idle and some bucking/jerking mostly at 35 miles an hour upon acceleration ,just had plugs changed a few days ago and bucking continues, idle seems worse after plug change,truck does not buck as much as B4 plug change.Also i changed the pcv valve a few minutes ago as in have a bad oil loss somewhere,no dripping,loosing around two quarts every 2 weeks,no smoking exists, and thats where i am starting on that issue.why do i have a rough idle ?why the oil loss? oh i am checking the cop"s one at a time with a new one,stating a number one. thanks for any help, andy
Old Apr 22, 2006 | 05:11 PM
FortyFords's Avatar
FortyFords
Bad cop
Bad wires (I forget does a 01 4.6 have them?or bad sparkplug boots)
vacum leaks
fuel pressure
fuel filter
Clogged injectors
Rich
Old Apr 22, 2006 | 05:15 PM
acourt's Avatar
acourt
thanks,i forgot to say i did have fuel filter changed at same time as plugs and i will work my way through cop's one at a time,thanks
Old Apr 22, 2006 | 05:39 PM
mattd17's Avatar
mattd17
possibly a bad or dirty MAF? when my COP went bad, it idled just fine, but would then get the stumble upon accel. just a thought.
Old Apr 24, 2006 | 06:52 AM
FortyFords's Avatar
FortyFords
I failed to mention the IAC (Idle air control valve) also.
Rich
