CHEAPEST & EASIEST A.C. MOD !!!!
Old Aug 10, 2007 | 09:11 PM
JIM ROLAND's Avatar
JIM ROLAND
Wink CHEAPEST & EASIEST A.C. MOD !!!!
If anyone reading this thread would like to do the cheap, easy, manual cut off valve method, the NAPA part # for the valve is 660-1414, clamps part # is 505-1212. I spent a total of $14.77 + tax for the valve and two 5/8" stainless steel worm gear clamps. I installed it on my 2000 F250 4x4 7.3 powerstroke next to the oil filler cap. It worked great today with outside temp. at 105 and heat index of 115. For anyone who may not know which heater hose to install it in, it is the one that carries hot water into the heater core, it will be the one coming from the engine and going toward the firewall, not the one which connects to the water pump. I mounted mine at this location for very easy access by just reaching in over the passenger side fender. It took a total of five minutes to do. When installing make sure your clamps etc. are not touching any other metal so you won't have any rattles or abrasion.This is for the guys like myself who just want an inexpensive easy fix. Thanks to all on this thread!
Old Aug 10, 2007 | 09:16 PM
edub32's Avatar
edub32
Can you get a picture Jim Roland?
Old Aug 10, 2007 | 09:26 PM
JIM ROLAND's Avatar
JIM ROLAND
Sorry edub32, I'm an "old school" guy and don't have the necessary "stuff" to do the pictures with... but I will be glad to help you any other way I can!
Old Jun 9, 2008 | 09:29 PM
JIM ROLAND's Avatar
JIM ROLAND
I just wanted to bump this back to the top again for my FTE neighbors! It has been really hot here the last few days so I closed my valve about two days ago. What a difference !! Give it a try if you haven't done an A.C. mod yet!
Old Jun 9, 2008 | 09:35 PM
big poppa's Avatar
big poppa
So basically, your cutting off the hot water from going into your heater core like the big rigs got, nice job. Can you really feel the difference?
Old Jun 9, 2008 | 09:36 PM
megawatt00's Avatar
megawatt00
Outstanding. Thanks for sharing all the info. I'd rep ya but the time out police have me!
Old Jun 9, 2008 | 09:44 PM
JIM ROLAND's Avatar
JIM ROLAND
Yep, that's exactly what I'm doing, and yes, it does make a big difference, especially when on "MAX A.C." I think if you try it you are gonna' like it !
Old Jun 9, 2008 | 09:51 PM
big poppa's Avatar
big poppa
Thats a big ten four jim, when i get back from vacation, i,m going to do it. It was 97 here today and went out and the AC was working hard. Thanks again, reps sent.
Old Jun 9, 2008 | 09:55 PM
DaveWilliams's Avatar
DaveWilliams
I just went to the Napa sight and searched the valve part number and couldn't find it. What kind of valve is it or what did they call it? Thanks, Dave
Old Jun 9, 2008 | 10:04 PM
JIM ROLAND's Avatar
JIM ROLAND
I don't think it has any special name if I remember correctly. Keep in mind that the original post was in August of 2007. The part numbers could have changed. Just ask for a manual cutoff valve for that size heater hose. It is very simple looking. It has a flat "T" shaped handle on it about an inch to 1-1/2" long, or wide, depending on how you look at it. The valve has a pretty fine thread so it screws up and down rather slowly. The whole thing will lay in the palm of your hand. It's not big at all. GOOD LUCK !
Old Jun 9, 2008 | 10:59 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Wish we could turn the heat off and the AC on up here. Just to wet and cold still.
Old Jun 10, 2008 | 11:31 AM
totin_tools's Avatar
totin_tools
Tom, you must be on the West side. I am out by Moses Lake and it has gotten alittle hot out here, but really its kind of nice, and dry.
Old Jun 10, 2008 | 01:04 PM
Kwikkordead's Avatar
Kwikkordead
Here in Seattle it is still only 58 degrees and raining. Snowing on Snoqualmie pass.
It's JUNE!!!!
Old Jun 10, 2008 | 01:14 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
It's JUNE!!!!
Dan, I wish I could give you a little of our mid 90*s temps. Just starting to warm up here.
Old Jun 10, 2008 | 05:04 PM
dustan52's Avatar
dustan52
Doing this mod doesn't increase any engine temps? Sounds like a good 'ol cheap mod i will have to do...
