Dp tuner boost numbers
Old Aug 10, 2007 | 08:02 PM
f350rebel's Avatar
f350rebel
i have a Overboost Annihilator and even on the 140 stage i can only get 20lbs of boost i cant figure out why.... Also i noticed now that i have turbo flutter where is the best place to get a wicked wheel...
Old Aug 10, 2007 | 08:41 PM
jtharvey's Avatar
jtharvey
Check the simple stuff first. Tighten your intercooler tube connector boots from the y-pipe to the IC on both sides, the clamps on the boot under the y-pipe, and the clamp from the compressor outlet to the y-pipe. If that doesn't help, look for leaking up-pipes that feed the turbo.
Old Aug 11, 2007 | 07:42 AM
f350rebel's Avatar
f350rebel
i will try to check everything today thanks
Old Aug 11, 2007 | 07:53 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
www.xtremediesel.com
Old Aug 11, 2007 | 08:03 AM
jtharvey's Avatar
jtharvey
Kris, are you trying to point to something specific?
Old Aug 11, 2007 | 08:08 AM
PowerstrokeJunkie
The wicked wheel, he asked where was cheapest.
Old Aug 11, 2007 | 08:14 AM
f350rebel's Avatar
f350rebel
do you notice a conciderable amount of difference after the install.... by that i mean power, economy, etc...
