Heads
Old Aug 10, 2007 | 01:45 PM
birddog16's Avatar
birddog16
Heads
With all the talk of the blown head gaskets it got wondering how are the 06 job 2 and new trucks holding up with the commonized heads ?
Old Aug 10, 2007 | 02:25 PM
Maxium4x4's Avatar
Maxium4x4
Friend of mine has an 06 with no problems, I believe the 06 is a good combination....add a tuner I would still head stud the engine.
Old Aug 10, 2007 | 02:41 PM
Enomra's Avatar
Enomra
All of us mid 05 and later 6.0 owners are wondering the same thing. I can say this "I have closely monitored this and other web sites regarding the 6.0 and I have yet to see one with head gasket problem on a 6.0 with a build date of mid 05 or later. That is not to say they are not out there, I have just not seen any. I have even seen a post on a 6.4 with headgaskets problems (the validity of his story remains in question) but none on the late 6.0. The local tech says all of the 6.0's he has worked on are early trucks and even they are getting few and far between as they fix them and they become very reliable!!!!!!!!!
Old Aug 10, 2007 | 02:45 PM
BowTieHatr's Avatar
BowTieHatr
there is no major difference in the pre commonized and commonized engine. they combined the e-series style and f-series style components and made one line of parts. funny thing. this is no more. before we were using the commonized head kits on 04s and up. not no more. they went back to the original setups.
Old Aug 10, 2007 | 02:51 PM
Enomra's Avatar
Enomra
BTH: What is your take on the HG issue then. Are the late 05 and on any better than the early models. If they are the same then why are there not many complaining about the HG on the later 6.0's and a majority of them seem to be tuned trucks also...
Old Aug 10, 2007 | 03:25 PM
badbrad60's Avatar
badbrad60
Maybe the early years for the 6.0 was a learning curve for both Ford Programmers and aftermarket tuners, and the 03/04 years took a lot of abuse due to programming. Lots of advancements in tuning of been discovered in the last few years to help the engines last. Also, didn't Ford slightly lower the compression ratio from 18.5 to 18.0. Every bit helps. And weren't the head gaskets improved on the newer models?
Old Aug 10, 2007 | 07:29 PM
BowTieHatr's Avatar
BowTieHatr
no headgasket improvements, no compression ratio change from what i know. most of the head gaskets were caused by over boost conditions and bad quality control. we had some heads that bolts were never tightened on a few engines. when they came out with the commonized kits, the head bolt tightning specs changed. same bolts, same gaskets, same engine.
Old Aug 10, 2007 | 07:55 PM
69cj's Avatar
69cj
05 psd and no problems, no mods, all maintenance done on time or sooner, knock on wood. Build was 12/03. I have no problems with mods but I also have no sympathy for people with mods when they have problems. Choose your poison, but don't blame some one else for the one that you choose.
Old Aug 10, 2007 | 07:58 PM
69cj's Avatar
69cj
PS, Don't flame me, Wife already does a good job of that!!!
Old Aug 10, 2007 | 08:48 PM
Maxium4x4's Avatar
Maxium4x4
I agree about quality control with what Bowtie said. International had more of a problem with quality than realized. New heads over the counter did not even meet Ford recommended specs and some techs reported loose head bolts upon inspection.
Mods or not head bolts failed. A good start is resurfaced heads with ARP studs. Do not turn this thread into a argument about warranty issues again...
Another question raised was replacing the bolts with studs and not removing the heads, I know some have attempted this method, I cannot tell you the final results. Best solution is checking the block and heads, apply studs then drive..
