Dumb question maybe?
Old Aug 10, 2007 | 11:44 AM
David85's Avatar
David85
I was wondering if any of you with 6.9s are noticing any real amount of pressure built up in the cooling system.
I seem to remember that when I first got my diesel, it would keep the rad hose soft even when the engine was hot, now it gets hard soon after a cold start. Is this normal? Or is it an indication of a leaking head gasket?
Old Aug 10, 2007 | 02:04 PM
Franklin2's Avatar
Franklin2
It should build up to the radiator cap pressure. If it gets higher than that, the radiator cap will let it puke out into the overflow bottle, and then onto the ground.
Old Aug 10, 2007 | 05:08 PM
David85's Avatar
David85
Well that certanly hasn't happened yet. Though my f150 did the the head gasket(s) started to leak.
The only reason I ask is because when I first got the truck it didn't build pressure at all. I guess its possible there was a contaminant at the rad cap that allowed the pressure to escape (or something), the 6.9 has a very large recovery bottle, so maybe thats why it never puked on me.
Old Aug 10, 2007 | 06:58 PM
catfish101's Avatar
catfish101
Dave I wouldn't sweat it to much. If or when it goes, you yourself will know.
The coolant level in my old 6.9 would stay right at the top of the cores in the rad. I could fill the surge tank up and with in a couple of weeks all the coolant would be gone down to the top of the cores and it wouldn't get any lower. It has been that way for years. I have had people call me about the same thing and I can't give them a good answer but drive it. I could sit here and think of several things that would sound good but to be exact, I wouldn't try unless it was an obvious failure.
Does yours do this?
Old Aug 10, 2007 | 07:34 PM
David85's Avatar
David85
Originally Posted by catfish101
Does yours do this?
Use coolant?
No, the level is always at the top of the rad, there are leaks at the rad that will need to be fixed though, so I do loose some coolant over the course of several hundred miles. The rad's number is up though, tomorow I will try to seal the leak, again.
Its never blasted coolant out the revovery tank, I was just wondering if its normal for the rad hose to indicate pressure only a minuite or two after startup, apearently it is.
Old Aug 10, 2007 | 07:43 PM
catfish101's Avatar
catfish101
Yeah an they will show pressure fast. The second the coolant starts to warm it will expand and being under the cap it could get tight fast.
