Sponsored by: Real Truck
2-3 shift clunk?
Old Aug 10, 2007 | 01:21 AM
007bronco's Avatar
007bronco
2-3 shift clunk?
Hi all. Just started noticing a slight clunking sound just as the tranny shifts from 2nd to 3rd gear. It's an 05 psd 4X4 cc with auto trans. It does it only at 2-3 shift under hard or easy acceleration and in or out of tow/haul. Are there solenoids that shift these trannys?. I dont think its a u joint or the carrier bearing
thanks all
Old Aug 10, 2007 | 07:01 AM
Casey's Avatar
Casey
Yes, the TorqShift is shifted by solenoids.
The clunk you hear is normal. It's a one way clutch that engages on the 2-3 shift. They all do it to some extent, some are worse than others. There is no fix.
Old Aug 10, 2007 | 09:29 AM
Storm's Avatar
Storm
The clunk you are hearing from 2-3 is due to the Band/Clutch driven pack.. There is a band that spins prior to the clutch pack engaging, when the pack engages you get a whiplash clunk from the already spinning band and clutch pack connecting.. If your getting a clunk that is good.. Normally 2-3, customers experience slipping and feel it's a danger because in theory everyone believes slipping is no good.. Even so some slip too and thats due to the band..
You are ok, 2-3 is one of the most crucial gears when towing, that is why the 5R110 was designed with a band/clutch pack setup for that gear to ensure at all times the gear is easily engaged with/without load..
Old Aug 10, 2007 | 12:45 PM
Casey's Avatar
Casey
Uhhh....NO. There are NO bands in the TorqShift. It's all clutches.
The clunk is from the OD one way clutch engaging on the 2-3 shift as the overdrive clutch releases.
Old Aug 10, 2007 | 04:27 PM
007bronco's Avatar
007bronco
Wow, thats great to know its normal. Thats why I love this site!
Thanks everyone
