conversion connectors for r134a
Old 08-09-2007, 08:50 AM
dbuck50's Avatar
dbuck50
dbuck50 is offline
When putting on the new high & low side connectors on a previously r12 system, should the old valves be removed before putting the converting connector on?
Thanks.
Old 08-09-2007, 11:36 AM
lsrx101's Avatar
lsrx101
lsrx101 is offline
Thanks.
It all depends on the conversion fittings that you use. If you're using good steel or brass fittings, you remove the old cores. If you're using the cheap Interdynamics aluminum fittings , usually: Low side-NO, High Side-Yes.
Old 08-10-2007, 02:57 PM
hhott71's Avatar
hhott71
hhott71 is offline
Dittos what lsrx101 said.
Don't use the Cheap stuff.
Spend the extra $4 for the real thing.
Decipha
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
09-24-2023 07:36 AM
thatsrealnice
10-01-2014 11:05 AM
desertt5
10-23-2013 08:22 PM
r-kid
05-13-2013 07:19 AM
eallanboggs
1997 - 2003 F150
05-24-2008 11:56 AM
Quick Reply: conversion connectors for r134a
