Extended front brake lines 77' F250
I'm finishing up a 3" front lift on my 1977 F250 Supercab complete with extended coils & shocks, re-bent ibeams, etc.. I haven't put the front 33" tires on yet, though I may (or may not) need extended front brake lines. Just doing my homework ahead of time in case I do need to get those extended lines. Not sure of the exact diameter of my present lines (it uses dual piston calipers, if that makes a difference), though any ideas on what F-series vehicle would have the same diameter lines with an overall longer line? Or where would be a good place to start my search?
Thanks in advance.
Thanks in advance.
Sorry for the delay. Attached a few pics. Will send more when complete. Just waiting for a bushing for my drag link/tie rod connection (impossible to find!) and the extended brake hoses. The bent I beams, coils, shocks, new drag link all came from John over at AutoFab....great kit.
Here's a pic of my brake hose and the one that I just ordered from 'Bronco Graveyard'. The new one fits a 1976 F250 4x4, but the end is a completely different angle from mine. Hope to make it work, can't find a Highboy front brake hose that matches my odd angled end...
Ok, now I can see the problem. My thought if it were me would be to move that bracket from the rear of the spring bucket to the front. I woul problably use a new steel brake line to do this. It look's lik it bolt's on, then I would use the hose you bought. Alittle creative line bending would be a cure. I am sure there are other's, but this comes to mind right now.
