Welcome to FTE . The firing order may be different . It was around 92 when the 302 went to 351 firing order. If it is let us know well will help . I know this because I had a 93 since new and it had old order. Later and happy trucking
Basically all you need to do is unhook all the wiring, fuel lines, and the exhaust where the manifolds meet the pipes. Pull the old motor out, put the new one in, and hook everything up. It'll run great. The engines are virtually identical.
